Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to do partial-volume heat generation? › Reply To: How to do partial-volume heat generation?
dlooman
It would be easiest and most accurate if you have geometry corresponding to the heated domain.  Then you could make a named selection for that body and issue the command below in a commands object:
BFE,named_selection_name,HGEN,,10  ! For a heat generation rate of 10
