Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Exporting a large number of data sets into TXT from varFDTD › Reply To: Exporting a large number of data sets into TXT from varFDTD
Matt Wilson
Apologies. I tweaked my code and it is now iterating through the range of wavelength values. I apear to have a seperate issue now though. I think there is a problem with how I am calculating the E field data from the Ex and Ey componants:
Ex = real(getdata("E_field", "Ex"));
Ey = real(getdata("E_field", "Ey"));
E_data = sqrt(Ex^2 + Ey^2);
x = getdata("E_field", "x");
y = getdata("E_field", "y");
z = getdata("E_field", "z");
f = getdata("E_field", "f");
x_max = length(x);
y_max = length(y);
z_max = length(z);
lambda = (c/f) * 10^9;
for (m=1:5){
fileName = num2str(lambda(m)) + "nm.txt";
E = E_data(1:x_max, 1:y_max, 1:z_max, m);
write(fileName, num2str(E(1:x_max, 1:y_max)), "overwrite");
The E field that is returned by my code differs from the E field that is seen in the monitor. I am pretty certain it is a misunderstanding on my end of how the E field is calculated from the raw data in the monitor. Can you advise how to fix this?
