Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › HOW TO CREATE SURFACE FIXED STRUCTURE OR POINT › Reply To: HOW TO CREATE SURFACE FIXED STRUCTURE OR POINT
(1) If your mooring line is not a nonlinear catenary cable
You may not need to define Structure A. Instead, just define a fixed point, and link Structure B with this fixed point by your mooring line.
(2) If your mooring line is a nonlinear catenary cable
By using the similar approach of defining Structure B (Buoy), you can define another structure (Structure A) from Geometry then share the geometry with the Hydrodynamic Diffraction analysis. In Aqwa Editor in Workbench, set Structure Fixity of the Structure A as "Structure is Fixed in Place", define the connection point on Structure A and a fixed point, define a rigid joint with these two points to link Structure A and the fixed point for the Hydrodynamic Response analysis. Another pair of the connection points should be defined on Structure A ans Structue B for setting up your catenary mooring line.
In Hydrodynamic Diffraction analysis, if the hydrodynamic interaction between Structure A and Structure B needs to be considered, these two structures should be in an Interaction Structure Group.
