Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Problem in generating surface mesh › Reply To: Problem in generating surface mesh
Keyur Kanade
This is very common error.
Sometimes it happens due to error in the geometry. Please check geometry in SpaceClaim.
Select geometry in structure tree --> Use right click --> Select Check Geometry. (Or Tools - Fault Detection in DM)
The geometry should be error free to proceed.
If geometry has any errors, please modify/recreate geometry at those places.
If geometry is error free then  please check if you have multibody component in SpaceClaim. If it is multibody component then you will need to use Workbench → Share option before going to Fluent Meshing.
Please go through help manual for more details
Please check following videos
SpaceClaim Share topology:
https://www.youtube.com/watch?v=h43E1YO1LiM
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
