Ansys Learning Forum › Forums › Discuss Simulation › Fluids › turbulent +laminar in an heat exchanger 2 channel › Reply To: turbulent +laminar in an heat exchanger 2 channel
jackzhe551
What will happen if I set the whole turbulent model ? does it substantially influence the heat transfer? It's supposed to be hot - turbulent and cold - laminar. and I have set the velocity and calculated the reynold number is turbulent, will fluent system systemically set a laminar mode to the cold fluid?
