Ansys Learning Forum Forums Discuss Simulation General Mechanical “AnsysWB Module has stopped working” when viewing results in Mechanical Reply To: “AnsysWB Module has stopped working” when viewing results in Mechanical
Barnaby Hawthorn
I have figured out some more detail which I thought might be useful to add:
I have another project file where the solution data is saved within the project, I have previously viewed the results and stress data etc. On this file I can open up Mechanical and view the solution/results just fine without any crashes.
HOWEVER, if I clear the generated data on the solution and re-read the results file (the same file.rst, which it was reading before without a problem) it immediately crashes again.
So it seems to be that the issue is with how Ansys is reading the file.rst into the project, this wasn't happening a month ago but happens now. Does anyone know why/how this might be happening?
