Ansys Learning Forum Forums Discuss Simulation General Mechanical Large deflection convergence problem Reply To: Large deflection convergence problem
dlooman
Your vessel radius appears to be around 10e-5 meters.  If R_in is the radial displacement in meters, you are approaching a solution in which the radius has almost doubled.  The model is probably unstable at that point.
