Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Automation with Lumapi and use of script commands › Reply To: Automation with Lumapi and use of script commands
Taylor Robertson
Hello Raksha,
This sounds reasonable it is likely that there may have been issues (possibly extracting the data from Q analysis groups) that cause the code to fail. This can happen in sweeps from time to time and you will need to understand why the analysis is failing to understand how to fix it. For point 4 you could also do this using load from files it should perform the same functionality.
Best Regards,
