Ansys Learning Forum Forums Discuss Simulation Electronics Mismatch in Resistance Matrix and Per Winding Solid Loss at high frequencies Reply To: Mismatch in Resistance Matrix and Per Winding Solid Loss at high frequencies
Reshmi Raghavan
Hello Zhansen,
Please check your mesh at 10MHz. The skin depth at 10MHz is 0.0208mm considering copper as material. If the mesh is not refined to capture the current destribution then the loss can vary.
Another thing to note here is that Maxwell is used for the low frequency simulation. Based on the below snapshot information we can confirm if Maxwell can be used for the 10MHz condition or not.
