Ansys Learning Forum Forums Discuss Simulation LS Dyna Do I need to set both surface contact and body interaction in workbench LS-DYNA? Reply To: Do I need to set both surface contact and body interaction in workbench LS-DYNA?
Armin
Hi Tomas,
If you have already defined your contact pairs, it is good practice to disable the Body Interactions.
You can check the knowledge material below for more information:
/knowledge/forums/topic/what-is-the-difference-between-body-interactions-and-contact-regions-in-an-explicit-dynamics-system/
