Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Export a variable value at a specific node set at the end of the simulation › Reply To: Export a variable value at a specific node set at the end of the simulation
March 6, 2024 at 9:33 am
Jesus Alierta
Hi Alex,Â
I've been trying to export the nodal velocities using the ls-prepost interface as you told me, but it is not working as I expected. It actually works with the shell parts of the model, but not with the Fluid (ALE) parts (it creates a file with the headers but empty values). How do I export the velocity values of the Fluid (ALE) part in which I'm interested? (see attached image). Thankw
