Ansys Learning Forum Forums Discuss Simulation General Mechanical Large deflection convergence problem Reply To: Large deflection convergence problem
hdonner
Hi Marcin,
in case of pressure loads in combination with large deflection, the stiffness matrix becomes unsymmetric. Thus, please go to Analysis Settings -> Nonlinear Controls -> Newton Raphson Option = Unsymmetric.
Further, if this stability issue appears, which is mentioned by Dave, I would activate quasi-static solution in the Analysis settings. Please take care that the material has a density. Last but not least, I would set the max. number of substeps to 1e9, allowing Ansys using very small time steps.
Were these hints successful?
Kind regards
Hendrik
