Ansys Learning Forum Forums Discuss Simulation LS Dyna Adjustment of stresses after calculation in LS-Dyna Reply To: Adjustment of stresses after calculation in LS-Dyna
javat33489
If I used the MAT ADD EROSION card:
1. Is it enough to use only one SIGY parameter? The rest seem to be unnecessary or unknown. This parameter would indicate the voltage above which it should be removed.
2. Is it possible to turn on the MAT ADD EROSION card not immediately but after some time? For example, after half the calculation it turns on and starts working?
