Ansys Learning Forum › Forums › Discuss Simulation › Materials › A solver pivot warning or error has been detected in the UX degree of freedom › Reply To: A solver pivot warning or error has been detected in the UX degree of freedom
March 5, 2024 at 5:42 pm
Hi Armin,
Thank you for the reply.
I attempted to connect the sphere to the cuboid using manual contact region to obtain the image below:
After I tried re-calculating I obtained an error on a different degree of freedom. Should I ensure all the faces except the face where the spheroid is, a fixed support as I would like to see the deformation of the spheroid against the cuboid.
