Ansys Learning Forum Forums Discuss Simulation General Mechanical How to see Convergence of results in ANSYS Mechanical APDL Reply To: How to see Convergence of results in ANSYS Mechanical APDL
dlooman
The problem is you are running in batch mode.  If you were in the APDL gui and you cut and pasted your commands into the input window (or input them from a file), then you would see a real time convergence graph.  You could add /gst,on,on to your commands.  That would write a file.gst which could be interrogated in the APDL gui with the Results Tracker while the job was running.  Easiest of all is to just look at the solution output (Solution Information) as the job is running.
