Ansys Learning Forum › Forums › Discuss Simulation › Materials › Shape Memory Alloy Analysis › Reply To: Shape Memory Alloy Analysis
March 5, 2024 at 4:03 pm
Armin
Thanks Tom.
I tried to re-produce a similar model to the one you described (just scaled down the wire length and applied displacement by 1/4 to save time).
I used the same material properties as the ones in the mentioned forum post. I was able to a get a converged solution. I added a few screenshots below, so hopefully they help you to resolve the issue.
