Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Large deflection convergence problem › Reply To: Large deflection convergence problem
March 5, 2024 at 3:58 pm
Large deflection is the "real life" solution. If it says you need a higher modulus you need a higher modulus. You can't go by the small deflection result.
