Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Error in PCM simulation on computing server. › Reply To: Error in PCM simulation on computing server.
Best way to check is run the journal locally, just set the iteration/time step  count to 1-2. That's how I check journals! My only comment is your time step wants checking - very roughly you want 10 time steps for the flow to cross a cell.
