Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Error in PCM simulation on computing server. › Reply To: Error in PCM simulation on computing server.
Muhammad Saqib
Hi Rob, thank you for your reply. I have done the same I have write the case file from my local machine. and then used start_fluent.sh and journal file to run on the server. can you tell the about journal file are all these cmds OK for transient simulation run through standard initialization? I can also share the journal and .sh file
