Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Ansys HFSS error when running example: hf3d exited with code -1073741795 › Reply To: Ansys HFSS error when running example: hf3d exited with code -1073741795
March 4, 2024 at 9:22 pm
Unfortunately, we don't have a mechanism to simply re-compile the application in such a manner. That suggestion also assumes that the AVX instructions in that one file are the only incompatibility involved in running HFSS on an M3 chip through Paralleles. Officially, I have to recommend that you try running on a supported CPU architecture, which would be Intel or AMD.Â
