Ansys Learning Forum › Forums › Discuss Simulation › Fluids › 3D geometry on AQWA and Coupling AQWA with Fluent › Reply To: 3D geometry on AQWA and Coupling AQWA with Fluent
Shuangxing Du
Aqwa calculates the time domain pressure over the internal tank hull, but does not calculate the fluid velocity, wave elevation inside tank.
The results can be exported into a common-separated values file. Please read Aqwa User's Manual, Section 5.11.9 Time domain Pressure Results.
