Ansys Learning Forum Forums Discuss Simulation Preprocessing Mesh issue Reply To: Mesh issue
mjmiddle
Hexa dominant can possibly make low quality elements at the center, which can be bad for convergence. Check quality histogram. View internal mesh with a section plane. If low quality is hurting convergence, you can mesh as tetraheral, which will produce more elements but better quality.
