Ansys Learning Forum Forums Discuss Simulation General Mechanical Element volume in USERMAT Reply To: Element volume in USERMAT
David Weed
The following code will give you the element volume fraction (volume per integration point):
DOUBLE PRECISION vect2(1)INTEGER v_num
v_num = 1
print*,'element num',elemId
print*,'int point num',kDomIntPt
call get_ElmData ('EJAC',elemId, kDomIntPt,v_num,vect2)
print*,'vect2 value',vect2
