Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Sample rupture in LS-Dyna ACT › Reply To: Sample rupture in LS-Dyna ACT
March 4, 2024 at 1:24 pm
Ram Gopisetti
Hi javat,Â
Are you sure you have calibrated the damage variables correctly from the test data?
I am not sure if you can equate the damage variables directly to the JC main model coefficient can you check if the reference you had is from a proper source? A is inherently a yield point and reaching such of level of damage is unusual and incorrect to work.Â
Check the following YouTube link for the calibration of the JC correctly with strain rate cases.Â
https://www.youtube.com/watch?v=F8BQNm-zYSM
https://www.youtube.com/watch?v=vRTgY1HikUQ
Cheers, RamÂ
