Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › AQWA :relative pitch RAO of two dependent parts › Reply To: AQWA :relative pitch RAO of two dependent parts
r.abbasi
Thank you, but I have already attempted that, and the results are not logical. This is because the hinge and its specific damping are being replaced with a stiffness(although bodies take apart again)!
As a result, AQWA cannot accurately capture the 'Angle Phase' of two structures connected with a hinge, while also considering the hinge (or other joint).???
