Ansys Learning Forum › Forums › Discuss Simulation › Fluids › “Floating point exception” error immediately as I run a 2D simulation › Reply To: “Floating point exception” error immediately as I run a 2D simulation
If you're adding fluid to a sealed domain you need to use a pressure function for density (ideal or real gas) or you'll not get a sensible result.
