Ansys Learning Forum Forums Discuss Simulation Fluids Specific heat UDF energy imbalance Reply To: Specific heat UDF energy imbalance
adave12
So the continuity residual does not converge. There is a large turbulence in the system, with vortices spreading longitudinally. I believe this energy imbalance behavior may be related to the increased Cp. However I have noticed that this occurs only for higher velocities . However, the flow behavior doesn't seem so different from lower velocities
