Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Fatigue Cycle Tolerance › Reply To: Fatigue Cycle Tolerance
February 12, 2024 at 5:39 pm
I am not certain what you mean by "models cycle". Do you mean the predicted fatigue life from the simulation? You can assess the tolerance for the predicted life using several techniques. If you are using the Mechanical Fatigue Tool (FT), you can paramertize any result and evaluate various Design Points. You can also use the Fatigue Sensitivity ouput to assess the variance in fatigue results.
