Ansys Learning Forum Forums Discuss Simulation Fluids NA Reply To: NA
You're welcome, and thanks for starting a new topic for a new question.
1) Up to you - how high is the building relative to the ABL? What is upstream to decide if the ABL has formed or been chewed up by the scenery?
2) Your monitor shows a roughly repeated variation every 50-ish iterations. Plot velocity contrours around the building every 5 iterations. Also pressure on the building. What do they tell you?
3) How long a transient did you run? Time step was probably well under a second, but what frequency do you expect the flow to change at?
The extra data from 2 & 3 will help you decide if the flow changes enough to need to worry about it. A transient flow may be a very small fluctuation that can be ignored, or a very big change that can't.
