Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Insert Geometry is failing on ANSYS Discovery › Reply To: Insert Geometry is failing on ANSYS Discovery
February 12, 2024 at 7:15 am
Hello Felipe,Â
From the above image it looks like your design in the current session uses large units. The model you are inserting might not be saved in large units so it cannot be inserted to this current session. You will need to start a new session and switch to Standard units to open that file.Â
You can insert large units models into large units session. Let me know if you have further questions on this.Â
DevendraÂ
