Ansys Learning Forum Forums Discuss Simulation General Mechanical Bending moment and shear force diagram Reply To: Bending moment and shear force diagram
peteroznewman
Bending moment and shear force diagrams have nothing to do with the materials. They only have to do with the loads and supports. If you have a 3D solid block of the correct length, not what you have shown with all the details of the inner foam core and outer shell, but a plain solid block, you can use the Prepare tab in SpaceClaim to extract a Beam model. Bring that into Mechanical and apply the supports and loads then solve. It doesn't matter that the material is Structural Steel.
You need to define Construction Geometry, a Path along the length of the beam.  Then under Beam Results, insert a Shear-Moment Diagram. Set the type to Directional Shear Moment and select the VY display.  Look at this discussion for an example.
