Ansys Learning Forum Forums Discuss Simulation LS Dyna How to output or measure the centrifugal force of a rotating object in LS DYNA? Reply To: How to output or measure the centrifugal force of a rotating object in LS DYNA?
Reno Genest
Hello Rex,
Could you give us more details and show an image of your rotating object? What is making the object rotate? For example, if you have a ball attached to a string going in a circle, the centrifugal force would be equal to the tension in the string.
Reno.
