Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Ansys Maxwell Field calculator “smooth” operator application › Reply To: Ansys Maxwell Field calculator “smooth” operator application
February 9, 2024 at 7:32 pm
HDLI
Hello Vignesh,
Please review the Maxwell help manual, Smooths the quantity in the top register. Because of the numerical solution technique used, field values are not always continuous across the boundaries of the individual elements that make up the finite-element mesh. Smoothing makes the values continuous. In general, use smoothing before plotting a quantity.
However, to get same result as report has, we will not use smooth function in the field calculator, and please only use values in each element.
HDLI
