Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › RSM configuration › Reply To: RSM configuration
February 9, 2024 at 1:14 pm
HelloÂ
This log indicates that you are using a custom RSM configuration or custom RSM file transfer.If you would like to use customization, then you will need to follow the RSM customization guide.
If you do not need customization, you can use the default configuration by following all the steps in this help page https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/wb_rsm/rsm_native_config.htmlÂ
