Ansys Learning Forum › Forums › Discuss Simulation › Fluids › UDF for multiphase flow › Reply To: UDF for multiphase flow
February 8, 2024 at 5:22 pm
y is the axial coordinate, with y comprised between 0 and 2m, x between -0.12 and 0.12m and z between -0.12 and 0.12m.
The contour represents only the region of interest, not the whole geometry.
The problem is that the udf does not correctly compute the distance from the column’s bottom.
