Ansys Learning Forum Forums Discuss Simulation General Mechanical creep analysis_ benchmark the data Reply To: creep analysis_ benchmark the data
BALAMUGESH M
hi,
i need to know, in experimental test analysis 0.143mpa load is applied in the top surface of the model, same i need to do analysis, instead of force i will apply 0.143mpa pressure in the top surface, so my question is if i cut my model into four symmerty part and apply the pressure, what will be the value need to be applied..?? will it be increased by 4 times are remain same??
