Ansys Learning Forum Forums Discuss Simulation Fluids Issue regarding [out of date] mesh in fluent Reply To: Issue regarding [out of date] mesh in fluent
Omkar Kulkarni
If you are getting out of date mesh please either replace the mesh with the newer version. Also, are you using Fluent meshing before solution mode? If yes, try to add shared topology in the Fluent Meshing and not in Spacecliam.
I hope this helps.
Thanks!
