Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Mechanical Scripting: Pressure Import componentwise › Reply To: Mechanical Scripting: Pressure Import componentwise
Dayana Behrens
thank you for your support.
The first part works, but I still cannot change the components of the pressure. When I try to add it to the code like that:
mechScriptCmds="""
wbAnalysisName = '{3}'
for item in ExtAPI.DataModel.AnalysisList:
    if item.SystemCaption == wbAnalysisName:
        analysis = item
mycaption = analysis.SystemCaption
ExtAPI.Log.WriteMessage(mycaption)
with Transaction():
    import glob
    import os
    DataPath = r'{0}'
    DataExtension = '{1}'
    allfiles = glob.glob1(DataPath,"*." + DataExtension)
    allfiles.sort(key=lambda f: int(''.join(filter(str.isdigit, f))))
    numfilestoload = len(allfiles)
    importedloadobjects = [child for child in analysis.Children if child.DataModelObjectCategory.ToString() == "ImportedLoadGroup"]
    usedimportedloadobj = importedloadobjects[-1]
    importedPres = usedimportedloadobj.AddImportedPressure()
DefineByProp = importedPres.PropertyByName('PROPID_DefineByType')
DefineByProp = 0    # 0="Components", 2="Normal To"
  namedsel_importedload = ExtAPI.DataModel.GetObjectsByName('{2}')[0]     importedPres.Location = namedsel_importedload     table = importedPres.GetTableByName("")     for i in range(numfilestoload-1):         table.Add(None)     for i in range(numfilestoload):         table[i][0] = "File"+str(i+1)+":"+str(allfiles[i])
        table[i][1] = "File"+str(i+2)+":"+str(allfiles[i+1])
        table[i][2] = "File"+str(i+3)+":"+str(allfiles[i+2])
      table[i][3] = (i+1)*100
  importedPres.ImportLoad() """.format(DataPath,DataExtension,namedSelectionUsed,systemName) model2 = system2.GetContainer(ComponentName="Model")  model2.SendCommand(Language="Python", Command=mechScriptCmds)
When I run it nothing happens. I have of course tried several writing variations, but it doesn’t work. The components are apparently not turned on and therefore no further columns are created.
I also tried it like that, but it also doesnt work… I have seen this spelling several times, but never for imported pressure
ImportedPres.DefineBy = LoadDefineBy.Components
Best regards
Dayana
