Ansys Learning Forum › Forums › Installation and Licensing › Ansys Gateway powered by AWS › Unknown Laas data error › Reply To: Unknown Laas data error
February 7, 2024 at 11:00 am
Finally you can validate that the system environment variables are set correctly to match the License settings file.
The default installation path should be found here: ("C:\Program Files\ANSYS Inc\Shared Files\licensing\ansyslmd.ini")
For the Elastic Licensing please review the environment variable: ANSYS_ELASTIC_CLS
e.g if using Windows command prompt you can print the variable:
echo %ANSYS_ELASTIC_CLS%
