Markus Wagner
Hi Nikunj,
thanks for your question. Which Version are you working with?
You can use optiSLang inside AEDT (example in help optiSLang in Optimetrics (ansys.com) )
or AEDT in the optiSLang application (example in help  Calibration of a Damped Oscillator Using Signals in Ansys Twin Builder ).
If you change criteria between AMOP and Optimization, then optiSLang could not know which is the best design from the AMOP.
In that case, you can go to "Start designs" of you optimization system (see picture)
Here you can "Import start values from system" (see picture). You can choose the best design from the AMOP,
which will be then the start design of your optimizer.
Best regards,
Markus
