Ansys Learning Forum Forums Discuss Simulation Fluids How to add a spring device between the two structures of AQWA, so that it will r Reply To: How to add a spring device between the two structures of AQWA, so that it will r
1317794602
I want to study the forces acting on the two hinge points on the right in the XYZ and RX directions. This requires limiting the movement of the middle two floating bodies in the RX direction. So, how do I add hinges to these four hinge points? I have used two BALLs and two hinges, but I cannot study the force in the Rx direction. Thank you for your answer
