Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Object Phasing through Plate › Reply To: Object Phasing through Plate
February 6, 2024 at 2:14 pm
Akshay Maniyar
Hi Shady,
Can you share the analysis settings image that you are using? Maybe the timestep used is not small enough to capture the contact properly. Try reducing the timestep and see if it helps.
Thanks,
Akshay Maniyar
