Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Radial displacement › Reply To: Radial displacement
February 5, 2024 at 2:11 am
peteroznewman
Coordinate frames are attached to ground, they are not attached to nodes or elements and do not rotate with a moving node.
Nodal displacements report the change in coordinates from the initial location to the current location relative to ground. That change can be measured in Rectangular or Cylindrical coordinates.
