Ansys Learning Forum Forums Discuss Simulation 3D Design Mesh defeaturing on propeller despite defeaturing being dialled. Reply To: Mesh defeaturing on propeller despite defeaturing being dialled.
Govindan Nagappan
Do you have a geometry edge along the trailing edge of the blade. If not, can you add one and see if that helps. If there is an edge, the mesher has to follow the edge when using patch conforming method.
Or can you add face splits to separate the trailing edge. This way you can add a separate face sizing to make sure it is captured.
