Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Acceleration in Symmetry Region › Reply To: Acceleration in Symmetry Region
Alessandro Giuliani
Hi Peter, Thanks for your answer. Ok, I'll try to convert the solid to line bodies but I have to make you a question before : the frame isn't welded. All bodies are assembled by means of bolt connections. So, can I explain this situation in Workbench with a line bodies model or should I consider the model as fully welded? The purpose of the work is to verify all elements, joints and screws (I hope my English is understandable). Thank you very much
