Ansys Learning Forum Forums Discuss Simulation General Mechanical Midside node stress result averaging Reply To: Midside node stress result averaging
Govindan Nagappan
Hi Theo,
Instead of using probe, can you export the midside node result data and check the values. You may need a command object to export the data. You can use PowerGraphics (/GRAPHICS,POWER) and turn on 2 element faces (/EFACET,2), which is valid for higher-order elements. You can list the midside node stresses with PRNSOL.  This could be redirected to a file with /OUTPUT command.
Example commands (nodify the commands as needed)
/post1
set,last
/graphics,power
/efacet,2
/output,my_result,txt,
prnsol,s,prin
/output
