Ansys Learning Forum › Forums › Discuss Simulation › Fluids › interrogating fluent dpm sampling output data › Reply To: interrogating fluent dpm sampling output data
ll00023
What's the value of parcel mass meaning from the sampling?
I set the bin's flow time. Fluent provides the total mass of particle parcels passing through during the time interval.
you can see the max value is about 6e-3 kg/s while my particle injecting mass flow rate is 4e-6kg/s. Is it casued by flow recirculating?
