Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › question about define joint in dynamics analysis with ANSYS mech › Reply To: question about define joint in dynamics analysis with ANSYS mech
dlooman
If it's possible you will be able to drag and drop the joints onto Solution (highlighted in your image.)  If you're not allowed to drop them on Solution then no.
