Ansys Learning Forum Forums Discuss Simulation General Mechanical Acceleration in Symmetry Region Reply To: Acceleration in Symmetry Region
peteroznewman
Hi Alessandro,
An acceleration load in the X direction is not a symmetric load when you split the model in the YZ plane at the center.  You need a full model.  An acceleration in the Y or Z directions is a symmetric load.
To reduce the model size, convert the solid geometry to line bodies with beam properties assigned. This can be done in SpaceClaim or DesignModeler.
