Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Too high contact forces › Reply To: Too high contact forces
February 1, 2024 at 6:43 pm
Hi Camila,Â
What do you mean by high contact forces? For beams, you need to use AUTOMATIC_SINGLE_SURFACE and then apply the force transducer to that contact as recommended.Â
Have you used some sort of filter here? It would be great if you could be given some context for your problem with some inline images.
Cheers, RamÂ
